HHWForum.hu Letöltések Programok TweakNow WinSecret Plus 6.0.1
Nem elérhető OS9999
Üzenetek: 50,898
Témák: 51,264
Thanks Received: 15 in 15 posts
Csatlakozott: Aug 2022
2025-01-09. 23:56
[Kép: e88b7e652f6e51f5f7f40348db0d85fc.webp]
Free Download TweakNow WinSecret Plus 6.0.1 | 22.1 Mb
TweakNow WinSecret for Windows 10 and 11 allows users to explore the hidden settings in Windows.
This app is specifically geared for Windows, grouping numerous registry settings and delivering them from an easy and safe user interface.
With TweakNow WinSecret for Windows, you can move the Windows taskbar to the top and change the taskbar size by editing the registry value. With any app modifying the registry, it is strongly advised to have a backup to restore from in the advent of an issue.
TweakNow WinSecret for Windows makes the process easier than directly doing it via Regedit, potentially creating critical problems for a novice user. TweakNow WinSecret for Windows gives you a smooth platform to perform these tweaks in a more controlled environment.
TweakNow WinSecret for Windows is a solid option for those that want to improve their overall experience while on Windows through a simple and easy-to-navigate app.
Plus Features
Auto Dark
Automatically change app and system theme mode to light or dark
Auto Wallpaper Changer
Updates your background every day or hour with beautiful images from Bing homepage
Folder Size Analyzer
Figure out which files or folders who taking up your hard drive space
Find Duplicate
Find and remove duplicate files
Process Manager
View detail information about all running processes and change priority level for specified process
Secure Delete
Completely and securely delete sensitive file from your hard drive
Smart Shortcut
Automatically specified priority level for your favourite apps
System Information
Show detail information about your system
Track Cleaner
Protect your privacy by eliminating traces of your digital activities
Transparent Taskbar
Make your Windows Taskbar completely transparent
Troubleshooter
Fix problem with Internet connection, icon, thumbnail, and Microsoft Store
Windows Secret
Safely and easily explore Windows hidden settings
Operating System:Windows 10/11
Home Page-
  TweakNow WinSecret Plus 9.2.0 + Portable OS9999 0 15 Tegnap. 12:29
  TweakNow WinSecret Plus 9.2.0 (x64) Portable SKIKDA 0 9 Tegnap. 09:39
  TweakNow WinSecret Plus 9.2.0 SKIKDA 0 8 Tegnap. 09:35
  TweakNow WinSecret Plus 9.1.0 + Portable oaxino 0 6 2026-04-17. 07:10
  TweakNow WinSecret Plus 9.1.0 + Portable OS9999 0 10 2026-04-16. 09:09
  TweakNow WinSecret Plus 9.0 + Portable oaxino 0 18 2026-04-15. 15:51
  TweakNow WinSecret Plus 9.1.0 oaxino 0 14 2026-04-15. 12:41
  TweakNow WinSecret Plus 9.1.0 (x64) Portable SKIKDA 0 17 2026-04-15. 09:22
  TweakNow WinSecret Plus 9.1.0 SKIKDA 0 13 2026-04-15. 08:47
  TweakNow WinSecret Plus 9.0.0 Final oaxino 0 13 2026-04-15. 07:00
